I am not putting any logic to this at all. I am just reporting what happens. There is no way that I can know what is causing it (so far as I know anyway).
I'm happy to provide details, but there are none that I can think of that are pertinant to this. I further reported that the anomoly is not present with xxxa version.
SO, version xxxa no problem. Version xxxf problem. I don;t know exactly where it came in, just that it is not present in xxxa and it is there in xxxf.
Symptom conditions are:
NO changes to any CNC parameters SAME MACH setup, SAME machine, SAME G-code. xxxa works fine, xxxf goes nuts as soon as it encounters a G20 or a G70 the scale goes completely bonkers. I did not measure the delta, but it very well could be 25x error and I can tell you for sure that it IS related to the metric G commands; G20 caused the problem and G21 correct it . . . which is why I speculated that they had gotten reversed somehow.
Is this anomoly not reproducible? Am I the only one having this issue?
What info can I provide that would be useful?
Steve
